t-5 transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2012, 10:16 PM
t-5 transmission
I am looking for a good GM t-5 from an S-10 to mount behind the inline 235 in my '51 Chevy. I need a unit from a 2.8 v-6 truck. Anyone out there have one or any good sources? I live in Ohio
Old 08-07-2012, 01:18 AM
every junkyard thats still open. the 2.8 5 speed was the most common combo ever used in the s10's...... the 4cyl trans has better gear ratios....will make it alot better out of the hole then the v6 trans
Old 08-07-2012, 08:41 AM
Thanks
I'll consider the 4cyl. trans.
Old 08-07-2012, 09:20 AM
RWENUTS's Avatar
Here's a link to all the info you might ever need on yout T5 swap.
TRANSMISSION - T5 Tech Links - THE H.A.M.B.
Old 08-08-2012, 08:18 PM
cal1320's Avatar
I used a 4 cyl T5 trans behind my 283 in a 56 chevy truck. They are not very strong so don't beat on it.
Old 08-08-2012, 09:15 PM
non of the t-5's have any gurth to them, if your looking for a hot rod t-5 your going to need to shell out the bread for a tremec
Transmission ID etc7407 Transmission - Rearend 1 04-23-2012 11:28 PM
what transmission is this garbock Transmission - Rearend 1 06-16-2008 03:32 PM
Help: Transmission ID gbowne1 Transmission - Rearend 5 07-28-2006 06:03 PM
c4 transmission noah Transmission - Rearend 2 06-23-2003 07:42 PM
Transmission RHipps Transmission - Rearend 1 01-12-2003 09:29 AM
