T-5 transmission codes needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2005, 10:46 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
The T-5 transmission has a 3 digit code on the tag and ink stamped on the side of the transmission. These indicate exactly what the transmission is.
Does anyone have a list of these FORD codes or know where I can find the list?
This list was published about 6 years ago in one of the Ford magazines.
Old 09-05-2005, 06:52 PM
I found a couple links for you.
http://www.5speeds.com/t5/
http://www.mustanggt.org/gttranny.htm
http://ddperformance.com/Trans%20ID%20chart.htm
Hope it helps
And on the seventh day, he created CHEVROLET
Old 09-05-2005, 07:43 PM
xntrik's Avatar
Originally Posted by Mikey_mike
Thanks, ill look them over
The first site is a good identifier.
The third site gives better info as per more specs, etc.
Thanks Mike, this is great information.
ray
Old 09-06-2005, 12:27 AM
Drive it Like u Stole it!
i'm assuming you only wanted t5s that sat behind a v8....
1352-034 Ford 1983 SVO Mustang 5.0 V8
1352-065 Ford 1984 Mustang/Capri 5.0 V8
1352-115 Ford SVO 5.0 V8 WC
1352-126 Ford 1985 Mustang/Capri 5.0 V8 WC
1352-141 Ford 1986-87 Mustang/Capri 5.0 V8 EFI WC
1352-165 Ford 1986 Mustang 5.0 V8 WC
1352-169 Ford 1986 1/2 Mustang/Capri 5.0 V8 WC
1352-199 Ford 1990 Mustang 5.0L V8 WC
1352-204 Ford Mustang 5.0L V8 WC
1352-208 Ford 1992 5.0L Mustang WC
1352-218 Ford 1993 5.0L Mustang GT V8 5.0 WC
1352-219 Ford 1994 1/2 5.0L Mustang SN95 5.0L WC
1352-239 Ford 1992-93 Mustang 5.0 V8 WC
1352-242 Ford 1994 Mustang Cobra 5.0 V8 WC
1352-246 Ford 1994 Mustang 5.0 V8 WC
1352-249 Ford Mustang All 5.0 V8 WC
1352-251 Ford 1993-prior Mustang 5.0 V8 WC
1352-253 Ford 1994-95 Mustang 5.0 V8 WC
Old 09-06-2005, 09:09 PM
xntrik's Avatar
Drive it like you stole it !!!!!! AMEN thanks
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
GM transmission codes scot Transmission - Rearend 3 04-27-2005 07:02 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
Color Codes needed TurboS10 Body - Exterior 2 06-11-2004 08:12 PM
transmission expert needed. CurtisL Transmission - Rearend 3 11-09-2003 12:30 AM
