T-5 on to a Y block - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2008, 09:11 AM
T-5 on to a Y block
I have a recently completed 1956 Ford sedan with a 272 Y block and 3 on the tree. Great motor but high rpm on the highway. I have a 1988 T-5 from a Mustang complete with bell housing, clutch and shifter. What might be the best way to go: adapter on the block to use everything or a simpler adapter on the bellhousing to use just the tranmission?
Has anyone used an adapter for this application?
Thanks,
Whyblock
Old 09-10-2008, 12:44 PM
59 wagon man's Avatar
i have a 59 ford was gonna run the yblock with a t5 but th4e motor let go. ***************************************
Last edited by powerrodsmike; 09-20-2008 at 08:58 AM. Reason: Classified ad. Please use the Hotrodders Classifieds for classified ads.
Old 09-20-2008, 08:52 AM
Y block adapter
Hello... ******************** ... what company did you get it from and what is the model #? I need to be sure that it will do the job ... so much info out there about adapters on the block and those that bolt on to the Y block bellhousing and which is better and what parts will fit and so on ... for example, does the T-5 spline fit right in to the Y block clutch?? Any info you can give me is appreciated.
Last edited by powerrodsmike; 09-20-2008 at 08:59 AM. Reason: Classified ad. Please use the Hotrodders Classifieds for classified ads.
Old 09-20-2008, 09:07 AM
powerrodsmike's Avatar
Wiki Edits: 161
Please don't advertise on the board, post in the free classified ads section here, or send a private message each other.
Asking to buy is the same as posting info about a part for sale.
Try wilcap for the adapter.
http://www.wilcap.com/webdoc8.html
Pat at wilcap will be able to help you.
You will probably need a new clutch driven disc.
Later, mikey
BE different....ACT normal.
Old 09-20-2008, 02:32 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
Go to mummert's for the adapter and all the needed parts. That is where the majority of us "Y guys" go. He has the adapters for the t-5 and C4.
http://www.ford-y-block.com/index.html
If you need more specific help with the swap there is a thread currently going about a t-5 being mounted in a pickup on y-blocks forever.
http://www.y-blocksforever.com/forum...15164-4-1.aspx
Hope that helps.
Old 09-20-2008, 03:47 PM
5 to yblock
i did myn at home, used a truck bell houseing , had the 292 flywheel drilled for the clutch from the mustang made a abaptor to go in the bell housing bore to bring the the demention same as the t5 spiget. made my own throw out tube adaptor and used y block throw out and release fork.. you need axcess to a lathe and and a supply of tubeing re the bell diametre reducer. i left the flywheel drilling to a pro machine shop, remember if useing the mustang clutch bolts are metric . the 5spd with od made for a great combo. cliff
Small Block Vs. Big Block rhanshaw Engine 30 12-26-2007 02:02 PM
Verify a 351w block. Not2psycho Engine 3 05-27-2007 04:23 PM
Big block questions, help please??? 67 sleeper Engine 20 05-15-2007 04:24 PM
Small Block to Big block pullies WakBordr7387 Hotrodding Basics 5 01-30-2007 12:35 AM
SBC Block I.D. Casting# confusion 1Fast65Elky Engine 2 10-13-2004 07:44 PM
