T-700r4 no reverse good line-pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2013, 08:34 AM
Hello all,
I have been having a hate/love affair with my TH700 R4 non electrical.
The transmission was bad so I took it apart, the engine brake didnt work very well and most of the times he would skip 2nd. After 150k miles.
I rebuilded it: new clutches, new 2-4 band, new seals
I check for cracks and wear on the hardware and put it back together.
During the rebuild I made some pictures while taking it apart.
After a week the workshop manual book arrived from the great USA.
the first thing I notist was that there where differant amount of checkball in my tranny then there were it the book. But I took pictures and the transmission was fine al the time before getting bad. So I put it in like I have taken it out.
First test drive after installing it back in the car. no Reverse.
When I select overdrive of Drive it kicks in pretty hard, like an manual transmission with a bad clutch.
All the forward gears work fine. Just the reverse is not present.
I have been measuring line pressure with the information from the book.
All gears are in the top pressure range of the table some even a little bit higher.
When I select the Revers it wants to move a little bit backwards (2inches) but then stops puching the car backwards of forwards when in R is not possible. I feels like there are 2 gears selected like the transmission winding up or something.
Also the engine Brake is very weak .
Is there anyone how can give me some advice, my feeling says it is something with these checkballs.
Cheers Arno.
700R4 Line Pressure Edgar86 Transmission - Rearend 8 01-03-2013 11:08 AM
700r4 line pressure? blacklabzeke Transmission - Rearend 5 10-25-2012 08:56 PM
what should be a good brake line pressure Augusto Suspension - Brakes - Steering 3 05-08-2012 10:05 PM
4l60e - No reverse after rebuild - Low line pressure? reddeth Transmission - Rearend 5 06-03-2009 09:12 AM
700R4 no line pressure rise mmather1 Transmission - Rearend 8 07-11-2008 07:40 PM
