T Bird Diff. Change - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2009, 04:34 PM
T Bird Diff. Change
I went through past posts and read about changing my 9" 3.0 to something like a 3.70 (66 Thunderbird). I know 0 about rearends so my question is... Can the 3rd member? be removed and replaced in one piece, easy swap out?
Old 09-20-2009, 05:00 PM
BOBCRMAN@aol.com's Avatar
Yes the center section drops out as a unit. Only problem you might have is incorrect axle splines on new center section.
Old 09-20-2009, 07:04 PM
thanks,
bug
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
Covert maunal column change to auto column change devious Transmission - Rearend 2 06-04-2007 01:10 PM
Pulley Change Out Long to Short Water Pump Mule Engine 7 05-25-2007 07:06 AM
Change 8 bolt front hubs/rotors to 6 bolt? (gm 3/4 ton) murrsue Suspension - Brakes - Steering 3 04-02-2007 01:05 PM
Can I change from a 28 to 26 spline carrier? artillerystevens Transmission - Rearend 0 03-05-2007 11:53 AM
