T Bird power rack question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2013, 04:45 PM
454 Rattler's Avatar
NEVER SATISFIED !!
I have a 85 T Bird power steering rack. The pinion shaft is too long. Can it be shortened ?
454 RATTLER
Old 08-06-2013, 08:17 AM
NEVER SATISFIED !!
Maybe that shaft is called something else. It's the short splined shaft that connects to the steering column with u-joints.
Is it solid ? Would I hurt the rack and pinion if I shortened it an inch or so ?
454 RATTLER
Old 08-06-2013, 01:44 PM
It won't hurt the rack, but the splines will be gone. How will you connecxt the column?
Old 08-06-2013, 04:50 PM
NEVER SATISFIED !!
I could just drill a small indention and run a set screw into it.
Thanks !
454 RATTLER
Old 08-06-2013, 08:26 PM
Thanks !
454 RATTLER
Not a good idea. There is upwards of 350 ft lbs of torque applied to that shaft under certain conditions, much more than a set screw can hold. The shaft at that point is only about 5/8" which is too small for a pin. You are going to have to think of another way that will be safe. I would try to do a mechanical connection like a double D
Old 08-07-2013, 08:13 AM
NEVER SATISFIED !!
Are the set screws ONLY used on the DD and splined shafts ? Are the round bore shafts only attached by welding ?
Thanks for the help.
454 RATTLER
Old 08-07-2013, 10:54 AM
ogre's Avatar
the 'Duracell Project'
quit teasing us
what build is this too long for?
Old 08-07-2013, 03:53 PM
454 RATTLER
Set screws are used to keep a mechanical connection together, rather than being the connection itself. You might be able to disassemble the rack and have the end recut to a smaller spline , like 9/16 by 36.
Old 08-08-2013, 07:36 AM
NEVER SATISFIED !!
Maybe you misunderstood what I want to do.
I want to SHORTEN the pinion shaft Not reduce the diameter.
This build is a 1936 Ford Sedan 350 with an original Mustang II crossmember. There is no room between the motor mount and universal joint.
The question is....Can I shorten the pinion shaft?
454 RATTLER
Old 08-08-2013, 09:16 AM
S10xGN's Avatar
Gotta love a turbo!
454 RATTLER
Yes, you can shorten it. As previously stated, there will be no way (short of welding) to safely attach a u-joint to it with the splines cut off or severely reduced in length. So you need to make up your mind if you want a one-off rack with a welded on u-joint or if you'd rather modify your engine bay to fit it properly.
Russ
Old 08-08-2013, 04:32 PM
454 RATTLER
I understood. Once the spline is cut off you have a round shaft left. Cut a new spline on the round shaft.
There have been a ton of cars done with Mustang crossmembers and 350 engines. You can make new brackets to rotate the rack for clearance, run the steering shaft through a hole in the motor mount bracket, or some other method. I have even spaced the left motor mount back for shaft clearance
Old 08-09-2013, 07:46 AM
NEVER SATISFIED !!
I noticed that aftermarket crossmembers have tapered mounts for the rack. I spent some time yesterday building new brackets to rotate the rack and that should fix the problem.
Does anyone know if the pinion shaft is solid ?
This all started when a friend told me Not to cut the shaft becaust it would affect the function of the rack and pinion.
Thanks for the help !
454 RATTLER
89 T-bird Rack & Pinion question solidaxel Suspension - Brakes - Steering 4 10-09-2012 04:41 AM
installing power steering using gm pump and t/bird Rack Bad Rat Suspension - Brakes - Steering 5 03-22-2008 12:51 PM
power rack question dbdbb Suspension - Brakes - Steering 1 08-22-2006 07:32 PM
power rack question S10xGN Suspension - Brakes - Steering 5 04-14-2006 07:34 PM
Adapting T-Bird Power rack to Mustang II sodas38 Suspension - Brakes - Steering 9 01-08-2005 04:32 PM
