I had to change the lower webbing out as it was to soft when I sat in the seat I was sitting on the floor! So much for "This is what we use for seat webbing"
So after searching for a week without luck trying to find a supplier in Canada that carried the correct seat webbing, I ended up using plain jute webbing. I wish I would have just used this earlier as it would have saved me a ton of hassle.
Once I got the webbing sorted out I started on the foam. I was planning on using 2 inches of C45 foam with 1 inch C45 for the bolsters. I was told I would need at least 3 inches of C45 (Thanks Dan), so that's what I went with. Of course When I originally set up the seats and body wood, I was planning on 2 inches of foam, needless to say I had to do some trimming.
Here is the base foam glued up, I missed a step or two here, sorry.
Then I marked out and trimmed some contours into the foam, I started using a flapper disc on a grinder, and it was way to awkward as evidenced by the slip there on the left. I finished up just using the electric knife, turned out to be much easier to control.
Once I had that sorted out I went a head and tested the fit in the car, this is where I noticed the extra inch....it totally threw off the feel of the seat.
So I marked out an inch and proceeded to cut, chisel, swear a bit, and chisel some more to get that wood out.
Now the seat back was back in its proper place:
Next up was the back, for this I used 1 inch of c35 for the base, and another inch of c35 for the bolsters, this shows the contour of the seat itself:
Next up was to add the bolsters:
I then trimmed the contours and tested the fit:
Everything looked good, and more importantly felt good, even the wife approved when I drug her out to the garage for a test sitting.
Now I can fit the steering where I want it.
