I thought I would share how I built my seats, I still have to make the patterns and seat covers but here is how I made the bases. This is my first attempt at building seats so if you notice something that will cause issues please let me know.
On to the build:
Okay its time to build some seats:
Okay, a couple months ago I had determined my seat rake and height using a stash of 2x4's, 2x6's, plywood and foam. Now all I had to do was make it all work:
First up lower seat supports:
Then came the base: Lots of tweaks, sanding, more tweaks. Then I finally realized that they do have to be so exact as vinyl, foam and side panels will all take up space, once I figured that out things when a little faster.
Since I have no padding on my *** I wanted a soft seat, so I decided I was going to use webbing to make things more comfy, the original cutout for the webbing:
After showing this it was pointed out that the opening for the webbing was to small as I would be sitting on the plywood and the webbing would not be doing anything, so I adjusted the width and made the openings bigger:
I then attached the supports to the base:
On to the build:
