T Bucket Body Dimensions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2009, 01:46 PM
I have been searching for some time on this forum for T bucket dimensions. Are they just all "what fits you" or are there actually dimensions that I can start my base from? Any help would be great. I have the frame dimensions just can't seem to find some good body dimensions.
Old 05-01-2009, 12:12 AM
Wiki Edits: 27
t bucket
try the Tbuckeeters site or NATB national t buckets alliance site
Old 05-01-2009, 04:55 AM
23 or 27?
Shane
Old 05-01-2009, 06:16 AM
cboy's Avatar
Last journal entry: Finished
Another trick that will get you very close on T-bucket dimensions is to buy a 1:25 plastic model and then very carefully measure whatever dimension you want to know...and multiply by 25. Some models are reduced on a different ratio but it should state it right on the box.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 05-01-2009, 07:00 AM
Wiki Edits: 27
t bucket
the firewall on my steel 16 T is narrower and shorter than my fiberglass 23 T also the contour of the seat back is different . a 27 is entirely different. some fiberglass manufactures have longer bodies .than original. Henry Ford wasn't very tall and the early bodies were comfortable for HIM. . some of the "!5 T " bodies have and exagerated rear seat kickup. some glass t's have a longer cowl for more leg room. Dimemsions on glass ones vary from different conpanies, I did a Steel bucket a few years using a 17 front cowl and a 23 touring doors and backseat. dimensions depend on what you get.
Body - Exterior "Tips of the Day" Jon Body - Exterior 11 09-07-2007 11:29 AM
Handbuilt aluminum body ckucia Body - Exterior 25 07-18-2007 12:15 PM
Pulling the body Rufus_2 Body - Exterior 8 01-15-2007 05:34 PM
32 Ford body, firewall and body bolts heyjude076 Body - Exterior 5 11-20-2006 05:57 AM
Hotrodders Knowledge Base: Body - Exterior Jon Body - Exterior 0 11-26-2005 06:33 PM
