T Bucket Build - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #46 (permalink)
Old 12-05-2013, 07:30 AM
NOX Mobile Build
Thanks killeratrod. Thanks Dave W. Would you happen to have some parts number Dave W?
  #47 (permalink)
Old 12-05-2013, 07:38 AM
Irelands child's Avatar
I don't have the front p/n in front of me, only a general description as these had custom brackets.
The backs, no problem:
Front Polished Dynalite ll w/’75-‘80Granada
Rotors w/polymatrix tanpads(140-2275-B)
Rear 20-5005 caliper(polymatrix tanpads 170-1827) (unpolished Dynalite ll calipers)
160-5844 hat
160-0276 rotor
(Modified w/spacers to fit ’57 9" axle offset)
Irelands child
The Following User Says Thank You to Irelands child For This Useful Post:
Sean Wong (12-05-2013)
  #48 (permalink)
Old 12-15-2013, 05:28 PM
NOX Mobile Build
IRS Rear End Geometry
Frustrated with the cold, I brought some of the work to my basement. Coming up with a rear end geometry wasn't easy. It took a number of tries but i was able to design a common plate to keep it all together.
I then used styrofoam to mock everything up.
The frame design itself is just about finished but there is a challenge regarding the the explorer end cover that I am using. The bolts are actually angled upward and everything is asymmetric. So before I start cutting tubing I would need to triple or even quadruple check everything.
  #49 (permalink)
Old 12-15-2013, 06:53 PM
I love your mocking up this thing as you are. You just can't spend too much time on mocking and templates.
The Following User Says Thank You to MARTINSR For This Useful Post:
Sean Wong (12-16-2013)
  #50 (permalink)
Old 12-15-2013, 07:00 PM
life is a temporary assignment
Looking good..
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
  #51 (permalink)
Old 12-15-2013, 08:41 PM
Good job ( I hate using styrofoam and all those weightless little pieces flying around my shop) I mocked my '31 frame up for the '32 gas tank with dimension framing wood and matched the steel to it size wise.
As far as being cold - wait til tomorrow
Irelands child
  #52 (permalink)
Old 04-05-2014, 10:45 AM
Last journal entry: New Rev wheels and BFG KDW II tires
It's finally warming up here in MN after hopefully one last huge snowfall. How's the project coming along?
  #53 (permalink)
Old 04-05-2014, 11:42 AM
NOX Mobile Build
Cold!
After the coldest winters in decades, it is finally warming up. However not consistent enough for me to do anything outdoors. I'll probably get going again in a month.
The Following User Says Thank You to Sean Wong For This Useful Post:
MARTINSR (04-05-2014)
  #54 (permalink)
Old 04-05-2014, 12:55 PM
Good to hear it, I am dying to see this thing moving forward.
  #55 (permalink)
Old 06-02-2014, 07:21 AM
NOX Mobile Build
It has been a grueling and depressing winter. Six month of cold weather and the coldest in decades. We finally have had 2 weeks of warm weather.
Over the winter, I had purchased a Model A wishbone front end. After my first mock up, I realized that my front frame section was a few inches too long. I have adjusted the length and measured the radiator to motor distance and it seems quick workable.
I also attached the IRS rear frame mock up and it seems to be just right.
I still have to move the motor back about 1 inch and will have to trim the transmission opening. After this, I'll be glassing in the floor, firewall, and making a transmission tunnel.
My seat were originally 1 piece but they had a huge recline and didn't quite fit. They have now been trimmed into 2 pieces. I quite like this look.
The manifold throttle bodies were soaked for weeks in degreaser since they were seized solid from carbon build up. Now they are spotless.
Hopefully the next time you see the motor, it will be painted to prevent further aluminum corrosion.
  #56 (permalink)
Old 06-02-2014, 08:05 AM
It's looking awesome Sean!
Sean Wong (06-05-2014)
  #57 (permalink)
Old 06-02-2014, 02:44 PM
NOX Mobile Build
Got an early Mustang steering box. Yahoo!
....and a 3 core rad from a 1965ish 6 cylinder Falcon wagon. The 6 cylinder has the correct location for the water hose.
  #58 (permalink)
Old 06-03-2014, 02:32 PM
NOX Mobile Build
Well the hope to keep this build purely Ford has been squashed. Got a great deal on a pair of 10" headlights off a 1928 Pontiac. Also picked up an original Model A rad shroud.
  #59 (permalink)
Old 06-03-2014, 06:14 PM
GRTfast's Avatar
Last journal entry: Seats
Looking good. Cool project!
The Following User Says Thank You to GRTfast For This Useful Post:
  #60 (permalink)
Old 06-04-2014, 06:01 AM
NOX Mobile Build
Profile Update
4.6 dohc t bucket
T Bucket Build Sean Wong Introduce Yourself 3 07-26-2013 06:49 AM
NEW T-Bucket Build ZackMethvin Hotrodders' Lounge 13 12-19-2011 09:44 AM
Want To Build T Bucket ROBERT REED Introduce Yourself 2 07-04-2007 08:13 PM
23 T-Bucket build www Hotrodding Basics 2 03-11-2006 07:41 PM
T bucket build? SMF Speed&Custom Hotrodding Basics 16 12-07-2005 11:23 PM
