t bucket crossmembers - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2005, 11:17 AM
dorksrock's Avatar
that one hot rodding kid
im planning on building a t-bucket and found a set of plans to build my own chassis. i was wondering about crossmembers, because im new to this area. could you guys hep me out on where to put them, and that stuff?
Old 06-05-2005, 12:56 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
I'd make one that would also act as a tranny mount.
Mike
Old 06-05-2005, 01:32 PM
dorksrock's Avatar
thats what i was kinda thinking, and then my engine could also act like a part of the structure also.
Old 06-05-2005, 03:31 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Basic chassis
When you get the basic rolling chassis done..front and rear axles in..the body set on..then you can set the engine bellhousing and tranny in place and let that tell you about the mounting..and where the crossmembers and engine mounts will go..
OMt
Old 06-10-2005, 01:51 PM
Tazz
Thats a very good point...
You will need the body mounts to be in place then set the engine and trans in and line up the motor and trans mounts accordingly...after the body is set in place.
Tazz
Rat Rods Rule!
Old 06-24-2005, 07:59 AM
snod83's Avatar
Depends on what material you are using really. If you are going with a thinner walled material you will want to run a solid engine and trans cross member. If you are running something like 1/4 walled material you can get by just using the engine as the cross member. I would also suggest if its possible to fit it into your build to use an X shaped member somewhere. This will give the typical ladder style T-bucket frame much more resist to twist.
Old 06-25-2005, 02:41 AM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
Speedway motors sells pre-fabbed engine and tranny mount crossmembers, might be worth looking into....
Old 06-25-2005, 05:14 AM
T-bucket frame is the simplest you could have....done right
When you begin the build of a bucket T frame you should have these components on hand:
1. The BODY with pickup bed or turtledeck. Without this how can you mount the engine/trans assembly or steering, or gas tank, or battery...get it?
2. The engine/trans...a junk block and empty trans case will be fine for mockup of motor mounts, crossmembers, etc.
3. The front axle and suspension assembly.
The front cross member is often round tubing or pipe. The front spring perch is welded to this crossmember. Yes, the "famous "suicide" perch!
The center crossmember is usually made of round tubing with a perch welded to it for the transmission support.
Some folks like to use a kind of tubular crossmember like the transmission one up under the engine. This would have the frame portions of the motor mounts welded to it on each side. This is the kind of crossmember you see in "universal" engine swap kits.
The rear crossmember may be rectangular tubing or round tubing and will have a spring perch welded to it if you're using a buggy-spring for rear suspension. If you're going with coil-overs, the crossmember would have tabs welded on for the shock mounts.
Some folks like to include another crossmember just behind the transmission one. It would usually be in line with the rear line of the "door" on the body or thereabouts and is used as a floor support/ seat riser board mounting member.
Some folks like to run 1/4"X2" piece of flatbar across the frame between the rails at the top of the kickup flush with rail on the slope as an additional support for the back of the body.
Old 06-25-2005, 07:14 AM
snod83's Avatar
Could you post a link to these? I have searched and can't find the engine crossmember.
Thanks,
Ryan
Old 06-27-2005, 09:19 AM
pmeisel's Avatar
http://www.speedwaymotors.com/xq/asp/dept_id.225/dept_name.Street+Rod+Products/qx/dept.htm
Try this....
T Bucket Steering and Radius rods plans ken47 Suspension - Brakes - Steering 11 02-01-2007 05:39 PM
T Bucket body? Studebaker Body - Exterior 7 12-31-2006 11:21 AM
power bucket seats scandal Interior 4 12-15-2004 10:00 AM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
Need bucket seats in Houston area JUSTINH Interior 11 11-07-2002 09:35 AM
