Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-bucket frame help
Old 09-07-2005, 08:49 PM
matt167 matt167 is online now
Wiki Edits: 31
Speedway will get you the raidius rods you need for a lot cheaper than CCR. I'd suspect that the longer raidius rods will have better ride, as putting them farther back or forward ( in the rear ) will position the suspension center, in the center of the car. The 4 36" rods sounds likely best because everything is balanced equally, putting the centerline of the suspension, compleatly within the center of the car.
