t bucket rear suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2009, 12:13 PM
Hey ya'll,
I'm missing my original rear leaf spring suspension on my 1923 t bucket I'm rebuilding due to, well, ignorance of others... Looking at the dimensions and perch plate it looks like an 1/4 eliptical set up. I am wondering if anyone out there has used a mono-leaf, made their own from compact car rear leafs, or has any suggestion of a good set up minus switching to a coil-over suspension.
Thanks, Mutt
Old 03-17-2009, 01:36 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Sounds like you could replace the quarter ellipticals, install a pair of shocks, and a panhard bar and be good to go. The springs will act as a trailing arm in addition to a spring.
Scrounge the wrecking yard for a good matched set of leaf springs off a mini pickup or small car, cut off the rear half of the spring (the end that connected to the shackle) to the right length to re-establish the proper wheelbase. If you use a multi-leaf spring you will have the option to soften the spring rate quite easily if necessary. With a mono leaf you don't have that option.
Andy
Jag XJ6 rear suspension with air rides ???? jimcar-9 Suspension - Brakes - Steering 18 06-17-2009 01:48 PM
Rear air suspension design ccrodder Suspension - Brakes - Steering 12 07-24-2006 11:14 PM
FatMan Wonderbar Rear Suspension Mega Suspension - Brakes - Steering 7 10-21-2005 09:42 PM
odd rear suspension problem william27103 Suspension - Brakes - Steering 1 10-18-2004 03:53 PM
lowering rear suspension Johnny Bravo Suspension - Brakes - Steering 1 08-31-2002 08:34 PM
