t-bucket rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2011, 09:22 PM
t-bucket rearend
hello
what is a good rearend to use in at- bucket
i heard maybe 90 and up , out of s-10
i have 12 bolt posi out of my chevelle , but think its to big.
any ideas
medical
Old 09-02-2011, 11:49 PM
Most T-Bucket owners want/or have a 9 inch Ford rear end.
The 57 Ford is the most desired one. It is narrow, has a drain plug in the bootom and looks the best
Old 09-03-2011, 07:28 AM
delawarebill's Avatar
rears
i'd also be looking at the ford 8".. mustang, falcon, maveric.. they are in the 55" range. thats the inside of backing plate. i honestly feel u'd be hard pressed to break an 8".. a friend had a blown 750hp on a bucket with an 8" posi... i like the '67 & '68 mustang for the axle tubes are the same OD the full length, were as the '65 & 66 are a step down... plus u don't need to cut those rears.. great size...
Old 09-03-2011, 09:02 AM
GT23T's Avatar
Originally Posted by medical
hello
any ideas
medical
The main thing to look for is a flange to flange measurement of 54 to 56 inches. I've seen both 8 and 9 inch fords, S10 rears, 8.8 fords, and 8 3/4 Mopar rearends used.
Old 09-03-2011, 10:02 AM
rearend
thanks for the advice
im just thinking the s10 rear because ,friend owns boneyard, cheap , plentiful, but i didnt even buy the frame yet. just thinking ahead
medical
Old 09-04-2011, 07:51 PM
12 bolt rearend
hi there
just measured up my 12 bolt chevelle rearend,54 inchs , think its good for my t- bucket project? any ideas out there. like to use the rearend so not just sitting there. any ideas'
medical
Old 09-04-2011, 08:25 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
medical;
I merged your two threads on the same subject. Lets keep stuff together when talking on the same subject ; your T-bucket
Old 09-05-2011, 04:46 AM
willowbilly3's Avatar
Last journal entry: Body mods
Ford Explorer rear ends are about the right width, cheap and generally tougher than the S10 rears. It is pretty easy to find them in limited slip and the gearing options are good too.
Old 09-05-2011, 05:05 AM
Irelands child's Avatar
A Ford 9" is overkill for most 2000 pound 'buckets and why Total Performance used the 8" out of a Maverick/Comet/Mustang for their entire run according to the former owner. Easy to work on, fair number of gear ratios to choose from, OEM and new and parts are relatively easily available. Unfortunately, these were not made after about 1980 and the entire rear end is getting hard to find as salvage yards clear out old stock. The later Mustang/Exploder rear, while it fits nicely, doesn't look 'pretty' with the 'tin' back covers and exposed bolts and neither do the 10-12 bolt GM - you do see the entire rear, wheel to wheel under there - but many do have an integral e-brake as well as discs. Toss up!!
Irelands child
Old 09-05-2011, 07:27 AM
Wiki Edits: 31
It's uncommon but I have started to see Toyota axles being used. There right in that 56-59", and have a drop out center section. 2wd shares the 5x4.5" bolt pattern with Ford and Mopar. has a couple odd gear ratios available like 4.30 and 3.58, but 3.42 and 3.73 are also available. They made 7.5 and 8" rears, and altho most 2wd's got 7.5", they could also get 8".. bit diffacult to decode, but there plentiful and would look right...
Expo 8.8 wouldn't look too bad with a finned aluminum cover.
Old 09-05-2011, 07:53 AM
grandpaws 57's Avatar
"Don't need no V/8"-grandpaw
Pozi
may I vote for 85 and back 7,5 out of 5.0 l mustang . Has limited slip and cheap. Many were swaped for 8.8.
Old 09-05-2011, 08:20 AM
seniormaster's Avatar
I'd use an 8.8 out of an explorer. You can even find them in most ratios without having to change them. 355 up to 410 are really common.
Old 09-05-2011, 05:12 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
I put a GM 10-bolt out of a S10 in mine. I later put in a Eaton Detroit Truetrack in this unit. My T-Bucket weighs 2040 pounds with me in it. Before I put the Truetrack in it, you could spin one rear tire without thinking about it - no weight on the rear end in these things. They leave a very light (but long) patch of rubber unless you're holding them in place for a burnout. The Truetrack helped with the hookup and I don't have to worry about the clutches in a conventional posi setup.
I tried to keep the weight on the two axles equal when I built it. Using a larger (heavier) axle made that difficult. If you're worried about breaking your axle, you can also beef it up with a differential girdle.
Bottom line, these cars are light and therefore don't see the driveline stress that much heavier cars put on their drivelines.
Old 09-05-2011, 06:44 PM
rearend
thanks for the advice cucumber
how did the 10 bolt look ,bolt in.line up pretty well. its just that i have the 12 bolt on hand
medical
Old 01-04-2013, 05:41 AM
I have heard about using the Explorer 8.8 rear end. What year(s) are we looking for? I have found that most hot rod applications are based on older parts which were readily available back in the day. If I have to go out and try to find a rearend out of a 57 Ford, it's going to be a long time building this baby !
'23 T Bucket SPORTINWOOD56 Hotrodders' Lounge 3 01-20-2008 12:03 PM
23t bucket rearend jcdiverdn Transmission - Rearend 3 09-24-2007 08:23 PM
T Bucket rearend tfeverfred Transmission - Rearend 21 01-17-2007 10:06 PM
T-Bucket GBRJ Introduce Yourself 1 09-30-2006 07:02 PM
T bucket help iceman32 Hotrodding Basics 3 06-16-2005 10:32 AM
