T fitting fuel - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2008, 08:00 AM
T fitting fuel
I was wondering what you thought of T fittings. I have a -8 line from mallory 140 pump that goes to a earls T fitting. It goes in one end then at the bottom of the T it goes into a reg for the carb that id feed by a -6. On the other side of the T so it has straight shot from the -8, I have a -6 line that is feed into a reg for a 100 shot of nitrous. Do you think this is ok. My reason for asking is I have a eddelbrock A/f monitor that when I punch it drops off but no backfire. I don't know it is the crappy A/F or the vacuum secondary 750 holley.
It is a chevy 350 400hp with 100 shot of nitrous. Fuel cell with -8. 3000 stall 3.70 3700lb 55 chevy.
Old 09-28-2008, 06:30 AM
It could very possibly be causing a restriction to fuel flow esp. when on the juice fuel will go to the point of least restriction, If it easier for it to flow to the n2o reg that may rob the carb port, a better solution may be a Y fitting.
Nitrous fuel supply ??? 67 Deuce 4 Me Engine 6 11-11-2007 09:30 AM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
Need help building a fuel system. staleg General Rodding Tech 1 05-16-2007 01:13 PM
Carb size to small???? brainsboy Engine 50 08-14-2005 04:04 PM
fuel cell installation 19nova72 Engine 5 11-19-2004 04:36 PM
