Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - t. p. i problems
Old 01-30-2013, 10:51 PM
Northstar T's Avatar
Northstar T Northstar T is offline
Gone sailing
^^^^^^What he said ^^^^^^
You can't run a MAF system with a MAP ecm. ain't gona happen. Because you already have the MAP based ecm, it would be simpler to convert to MAP, assuming your wiring harness is for the MAP system also, but either system will work fine. they just both need to be talking the same language.
86-89 is MAF and 90-92 is MAP btw
Russ
