Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - t. p. i problems
Old 02-24-2013, 07:26 AM
123pugsy's Avatar
123pugsy 123pugsy is offline
Last wiki edit: Metal shaping
Wiki Edits: 29
Originally Posted by LATECH View Post
The correct ECM for your application is a 1227165.
The wiring harness should have 2 connectors going to the ECM and not 3.
You probably have a harness for a TBI setup from a 1227747 which is what pugsy pictured and it wont run a TPI system correctly.
Seeing a few more pictures would help sort through this mess.
The ECM I posted is a 7730 from a 92 T/A (speed density). OP's ECM is supposed to be a replacement for this, from what I searched.
Name:	Copy of DSC03538.JPG
