Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - t p i problems
Thread: t p i problems
Old 02-27-2013, 12:20 PM
hcompton's Avatar
hcompton hcompton is online now
Old & Furious
Originally Posted by bigdog7373 View Post
This is so obnoxious. The tpi is a decent system.
Op: what is your problem? We can't help you if you don't say what's wrong.
If you're running a cut harness then 99% of the time you have to have the computer tuned. Basically it's looking for signals that it's not getting.
What part of the tpi is a good system? Mine was junk. Replacement cost was more than it was worth and a carb makes more power with less problems. The tpi does not flow is its most killing problem even with all the best stuff stock manifolds will not make much more than 300 hp no matter what mods are done sep for boosting it.
Now with boost they work ok. great for turbos give good low end tq. But for NA engine that will spin over 6000 rpm then the tpi will not work. They are so small the engine will not make power above 5K rpm some say 4K rpm is the max for the system. My vette came with the best gm had to offer it was still crap.
The simple fact is clear to anyone that has any knowledge of tpi. It is designed to make max power at 2500 rpm. below that is good above that is good. But get to far away and it will clogged your engine worse than running a two barrel carb. Most two barrels will flow more air than the stock tpi system.
Yeah good system but if you want power let it go. get a bigger manifold and tbi or lt1 or edelbrock system or just a nice big carb. all are way better. Carb only cost a few hundred bucks and your back on the road.
The Following User Says Thank You to hcompton For This Useful Post:
chphlds (02-27-2013)
