Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - t p i problems
Thread: t p i problems
  #20 (permalink)
Old 02-28-2013, 05:14 PM
LATECH's Avatar
LATECH LATECH is offline
Well.....in picture # 1 I see a map sensor, or is it the barometric sensor?
If it is a baro it shouldnt have a vacuum hose hooked to it.
I dont recall if these used a baro or not. The sensors are both different, even though they appear similar.
You may need both, and you could have the one in the photo plugged in to the wrong spot, or have the wrong sensor.
Picture 2 +3 I see a purple and yellow wire clipped and not connected. IIRC that pair is for the coolant temp sensor
Picture 4...question......the 3 wires...black/white, green,orange....were they clipped from The ECM connector? Or ?
Picture # 5 ...those rusty bolts with the Torx drive in the intake...need to be replaced with some allen drive anodized bolts (stricly for appearance ) LOL. Good photo session.Pictures really help.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
chphlds (03-01-2013)
