Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - t p i problems
Thread: t p i problems
  #24 (permalink)
Old 02-28-2013, 09:08 PM
64nailhead's Avatar
64nailhead 64nailhead is online now
Soul Hunter,
MSII with 3.57 PCB. Also using the relay board. Assembled units for both. It was my 1st MS install and I was a little scared of soldering the boards. The next one I'll build myself. I have to admit that using the assembled units is pretty close to plug and play other than the harness routing.
I can't wait to get it on the dyno - SPRING IS ALMOST HERE, as it's snowing outside
Back to the OP. CP said in an earlier thread that the 9th injector was plugged into the harness. It should not be with a MAP system. But I couldn't tell if the second coolant sensor, that controls the 9th injector, is installed. Can anyone see it in the pics?
