t p i problems - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-02-2013, 03:36 AM
64nailhead's Avatar
If you are indeed running rich (smell fuel) at cold start, then do not hookup the 9th injector as its only purpose is to INCREASE fuel delivery at cold temps.
Looking back through the posts, your original question is still unanswered, about ECM part numbers. I think you should find out that answer from the person that put this setup on the car. HOPEFULLY, he will be more than helpful. As I mentioned earlier, the harness and memcal can be custom made to work on most any other TPI engine (except '85 that had the MAF Burnoff module).
Questions for the installer :
What exactly was done to the memcal in terms of custom programming? This answer should include what systems were turned off, i.e. VATS, A/C override, trans OD, and was any custom programming done to fuel tables, cold start tables, etc.
What exactly was done to the harness to get a MAP ECM to work with a MAF system in terms of ECM pinout changes? Like you mentioned in your original post, there is a 3 plug ECM with a 2 plug harness.
Is the engine stock? If not, then what has been done? Cam & injector sizing & fuel pressure increases are some of the most difficult to overcome with GM programming.
Hopefully, he can answer all of these questions precisely. Write down, record, scan whatever accurate info he can provide. From looking at your car in your profile pics it appears to be a professional looking job, I would assume and hope the engine install was also.
Now, more possible causes :
Where is the O2 sensor? Is there an 'X' pipe or crossover between the dual exhausts? The sensor needs to be in the 'X' or crossover.
Is the O2 sensor heated or non heated? I assume it is the original narrowband. A common situation that could be causing your issue is the stock nonheated O2 sensor was moved off from the manifold back to an 'X' pipe and it takes some run time to get warm enough to read accurately which in turns cause the engine to run overly rich until the exhaust gets heated.
As JoshP asked, is the MAF relay working properly? I believe the main purpose of that relay is to provide enough amperage to clean the MAF sensor. Incorrect MAF reading can cause a rich or lean condition.
You might have an injector(s) on the way out and not sealing properly until it gets some temperature into it.
You could have a severely biased or nonfunctioning intake temp sensor.
FYI, I figured it wouldn't be as easy as unplugging the 9th injector
Good luck!
The Following User Says Thank You to 64nailhead For This Useful Post:
chphlds (01-05-2013)
to many problems!!!! Linez35 Hotrodding Basics 7 01-05-2012 11:31 AM
gm 2.8 problems... Jim Rockford Engine 4 02-28-2010 03:42 PM
Must II Problems Bobt22 Suspension - Brakes - Steering 9 03-16-2008 05:08 PM
Lifter Problems/Head Problems lewisdanw Engine 4 04-16-2006 01:47 PM
C4 problems ranger crazy Transmission - Rearend 6 03-19-2003 03:08 PM
