T-stat housing with filler neck - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2012, 07:13 AM
GMR GMR is offline
Thinking about using this setup plus an overflow tank instead of my current setup - 327 chevy, closed radiator, expansion tank.
Any issues to be aware of with the T-stat filler neck?
Old 06-16-2012, 09:10 AM
bondo's Avatar
Ayuh,.... Only that they tend to be Lower than much of the cooling system, makin' it awfully hard to fill it, as water seeks it's own level...
Coolin' systems are best filled from their Highest point...
Old 06-16-2012, 10:10 AM
GMR GMR is offline
ok, thanks
Gas filler neck strummin67 Body - Exterior 2 06-12-2012 07:41 PM
Gas Tank Filler Neck options? JhnBrackett Body - Exterior 10 09-05-2011 09:40 PM
Gas Tank filler neck HaydenP Hotrodding Basics 3 06-14-2011 11:56 PM
Leaky water neck- thermostat housing..any ideas? JKear Engine 5 08-16-2010 01:56 PM
pukeing fuel out the filler neck Rob Keller Hotrodding Basics 8 12-16-2005 07:21 AM
