T.A. wiring issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2006, 02:20 PM
T.A. wiring issues
First off let me say I am a mechanic However I am NOT an electrician. My problem is that mt 77 Trans Am has this on again off again problem. Something under the dash pops and my tach and power windows quit working. It may stay that way for a week or maybe just 10 minutes. Then it pops again and everything works. Its not the grounds and its not the circuit breakers for the windows either. Upon visual inspection there are no visual burns anywhere or naked or shorted out wires. Any Ideas???
Old 07-04-2006, 05:26 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Disconnect the battery, Carefully Pull the fuse buss..and check the back of the buss, where the wires solder into the Brass bars..
Upon careful inspection, I'll just bet you'll find a broken solder joint to one of those bars..And If so, carefully re-solder it back onto the bar.
The only other cause I can think of If your SURE the wires are not suspect, Is a faulty fuse holder..(loose connection)..check for that..
To find the buss bar problem, before pulling the fuse buss, and power connected, with the problem in evidence, get out your DVOM, set for VDC, V X 50 , or auto range, and measure on BOTH sides of the fuses on those items..If they are dead on BOTH sides..it's the feed to the bar..
Happy 4 th Of July!
Hotrodders are the
Most independent
group of individuals
today..
So I guess It's our
Day too...
Doc
Old 07-04-2006, 07:58 PM
Thanks I will try that tommorow at work. I will let you know what I find.
EZ wiring project zipfactor Electrical 3 05-21-2006 03:55 PM
Alternator Wiring question 65Stanger Electrical 8 04-29-2006 02:28 AM
Ford distributorless wiring issues n' stuff Th3 T0y M4k3r Electrical 18 12-27-2004 05:18 PM
Wiring with fiberglass wbmusarra Electrical 1 11-13-2003 05:18 AM
S-10 wiring issues....need a diagram TurboS10 Electrical 5 09-26-2003 10:35 AM
