t10 swap, is t10 longer than t5? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2003, 02:49 PM
Last journal entry: New photos
Post t10 swap, is t10 longer than t5?
Will a t10 bolt up to a 3rd generation camaro and what is involved in the swap? Also, is there a length difference and will the t10 sit farther back in the chassis?
Old 01-28-2003, 06:44 AM
New Member
Post
I have a GM A body car. I have had a M20 AN M22 & A T10 in this car. The car is an origonal 4 speed car and has a console. The shifters all came out perfect however the output shafts on the M22 & the T10 are larger. I also belive I had to shorten the drive shaft. I hope this info. is of some help.
