t5 trannies - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2007, 10:11 PM
t5 trannies
Does anyone know if s-10 trans are interchangable between 4cyl , 2.8 and
4.3. I currently have a 4.3 with a 700R4 and would like to convert to a
standard.
Old 10-12-2007, 11:00 PM
standard.
T5 trannnies were not installed behind the 4.3L in the S10. I think the trans for that engine was the NV3500. That would be the one to use for the easiest swap.
Bob
Old 10-13-2007, 01:05 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
There was one year I believe that t5s were behind the 4.3, but not sure. Either way, the t5 was installed behind small blocks in camaros and firebirds.
The 2.8 t5 has the small bellhousing pattern, smaller input shaft, and (possibly) weaker internals. Just get one from a V8 and you'll be better off.
Old 10-13-2007, 02:33 PM
I agree, but in many cases, where the car is light, and the power on the low side, the V6 Camaro/ Firebird T5 can be an inexpensive alternative to the V8 version. It has a 1"-14 spline input, but is the same length as the "traditional" Muncie/Saginaw input. I just put one behind a 4.3L Chevy V6 in my T roadster. Used an Astrovan flywheel with 11" clutch and it was a bolt on.
Bob
Old 10-13-2007, 03:08 PM
t5 trannies
Thanks guys for the input it will be alot of help.Hope to start a journal once I get this project under way. A chopped 46 chev on the s-10 chassis
re: Question on T5 swap gmac66 Transmission - Rearend 2 06-30-2006 10:18 AM
th350 to t5 swap? Mikebox Transmission - Rearend 1 07-13-2004 08:16 PM
t5 tranny or c6, hydraulic clutch martion Transmission - Rearend 2 08-25-2003 11:29 PM
Anyone have any Max capable Torque specs for chevy T5 trannies? FroFro Transmission - Rearend 1 08-08-2003 01:23 PM
BW T10 or World Class T5 onebadmerc Transmission - Rearend 0 01-21-2003 05:45 AM
