Tach Bouncing - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2006, 05:24 PM
crusherdbuzz's Avatar
71 Chevrolet Nova
Tach Bouncing
I just installed my new sports comp monster tach 5" with shift light. Under WOT the needle will bounce around 3,000 and then will restabalize around 4,000 rpm. The main problem with this is I am running a shift light. When it bounces it sometimes fires the shift light by hitting the 5,000rpm shift set I have. I don't like this because I sometimes run my car hard and don't want to do a false shift. The other time I notice the needle bouncing is when I completely let off the pedal it will also bounce. Anyone run into this problem and know the remedy? I know it has something to do with the signal it is receiving from the hei terminal.
Other relavent information: 71 nova, 350 engine with 4spd manual trans, hei ignition.
Appreciate the read and replies,
Dennis
Old 09-23-2006, 08:04 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
What TYPE HEI? GM or aftermarket..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-23-2006, 11:59 PM
71 Chevrolet Nova
The main body of the HEI distributor is red and there is a mallory sticker under the hood. However, the cap says Delco-Remy. So I am not entirely sure, but I am hoping the description helps lol. I didn't put the HEI in so I can't say for sure. I hope that helps.....
Dennis
Old 09-24-2006, 01:22 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
What one does it more resemble?
This one ?
Or this?
Doc
Innovations
Old 09-24-2006, 10:03 AM
71 Chevrolet Nova
I would have to say the first one. I say that because of the way the base of the distributor looks compared to the second one. Mine is flat like the first one not like the angled cone of the second.
Dennis
Old 09-24-2006, 06:37 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
OK, If it is the top..It's Stock GM...and only Good to about 5500 RPM before it takes a nosedive...And 4000 RPM , under module heat / Stress might cause it to "Act Up " a bit there..
The Performance HEI is good to About 8500 RPM before it runs like crap in a can..
My First piece of advice is pull the tach wire (and shift lamp) and hook up a Shop tach, and try to duplicate the problem..If you can't , one or the other (Tach or shift lamp) is headed for the happy hunting ground..IF you can...
Then verify the RPM range is accurate..AND If so, have the module and coil checked..at auto zombie for free, SEVERAL times, Full load, to heat it up good..see if it is thermally breaking down..
If you need either..BE sure you have them tested BEFORE you leave the store as well..Fail rate out of the box is very high..and once you leave .. it's your problem...
Try that, and let us know the results..
Doc
Innovations
Old 09-24-2006, 06:56 PM
71 Chevrolet Nova
Sounds good doc, I will try the shop tach tomorrow and just snap the throttle with the car parked because it duplicates the same thing now and will let ya know what happens. I've owned the car over a year and a half and have never done anything to the ignition system. Would it be a good idea to get an msd or petronix HEI upgrade kit and use it on that? I really hope it isn't the tach as the tach is brand new.
Old 09-24-2006, 08:31 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Well, Maybe for Street and better economy ... If you want to put the money into it..
But from what you describe..and Not knowing anything about the engine..sounds like it 's bone stock..and an HEI (Stock GM) should perform for you just fine..
Because it say's 10,000 on the face plate..doesn't mean you need try to reach it.. Especially if you don't have the rest of the engine to support it..(like a performance lower end for starters..heads, and induction..)
Think about it..Just how many times are your EVER going to reach 5500 RPM?? Not that many in a DD.
Choice , Of course , is yours..but to begin with..I'd invest it elsewhere first.
Doc
Wow!! Got blown off the site at 5:45 PM Ca local time..from overload..just now getting back in..7:30 Ca local...Thats special...
Innovations
Sun Tach 383vette Electrical 6 12-30-2011 02:21 PM
Tach cool rockin daddy Electrical 3 09-22-2006 04:12 PM
OER tach cool rockin daddy Electrical 2 09-01-2006 02:28 PM
Tach Problems thecrowx Electrical 3 07-09-2006 04:05 PM
mustang tach wiring stang_steve Electrical 0 07-14-2004 07:28 PM
