tach issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2013, 12:00 PM
tach issue
Hello everyone 1st post. am running a 1964GTO with a 455. I hooked up a sunpro retro tach sst802r. the coil is a mallory promaster 29440 and pointless distributor . All installation is correct however the tach is reading 6,000 rpm's at idle and is erratic after that.
Old 04-22-2013, 12:42 PM
life is a temporary assignment
Check to see it it has a switch on it to switch from 4,6, or 8 cylinder.. Some have a switch on them..
Old 04-22-2013, 01:40 PM
kleen56's Avatar
Also make sure the green wire to the coil is on the (-) distributor side of the coil and not the (+) side.
The Following User Says Thank You to kleen56 For This Useful Post:
NEW INTERIORS (04-22-2013)
Old 04-22-2013, 03:52 PM
tach issue
Yes to both replies. I actually took the tach apart and made sure the switch was on 8 cyls. Would a higher voltage output from regulator effect the readings??
Old 04-22-2013, 04:15 PM
kleen56's Avatar
Are you talking voltage regulator for the alternator? That should have no effect on the tach. A high voltage coil won't make a difference on reading either.
Old 04-22-2013, 04:20 PM
thanks . that eliminates 2 possible causes. It is a new tach by the way.
Old 04-22-2013, 08:04 PM
kleen56's Avatar
Could be a defective tach. Take it back and exchange it, then see if the same problem occurs with the new one.
tach issue Paddy D Electrical 2 01-06-2013 01:59 PM
HEI, Vacuum, and Tach issue mscaggs Engine 7 04-09-2012 08:45 AM
Best 60s Issue of Hot Rod Magazine and best 50s Issue of Car Craft MXrider13 Hotrodders' Lounge 18 07-29-2011 02:55 PM
vacuum issue or carb issue idk for sure chevyok06 Engine 1 07-10-2011 06:19 PM
10-12 Bolt U-joint Issue Issue MrB Transmission - Rearend 3 09-29-2007 09:17 AM
