tach issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2009, 02:24 AM
usmcsawgunner's Avatar
tach issues
i put an edelbrock 350 crate in my buddy's 86 monte carlo and routed the tach wire to the negative side of the coil. im pretty sure its not reading correctly but i think it might just be a little off. is there a way to test that? i have set the idle as low as i can without it stalling out and its still showing about 13-1400 rpm. and when i drive it, it just seems to be showing higher that what it should be. do i need a tach adapter and if so which one. its got an msd probillet ready-to-run dizzy and a blaster ss coil on there. its the stock tach
thanks
Dean
Old 03-31-2009, 03:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If it's an aftermarket tach, check the back to see if there's a selector switch to choose 8, 6, or 4 cylinder apps.
It might be on the wrong setting.
If it's a coil-in-cap HEI, there's a dedicated post for the tach on the coil/coil cover. It's left of the +12VDC post.
Sun Tach 383vette Electrical 6 12-30-2011 03:21 PM
New motor and tach issues mattson70 Engine 1 06-20-2007 01:17 PM
Tach cool rockin daddy Electrical 3 09-22-2006 05:12 PM
Tach Problems thecrowx Electrical 3 07-09-2006 05:05 PM
mustang tach wiring stang_steve Electrical 0 07-14-2004 08:28 PM
