tach light doesnt work - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2010, 01:24 AM
hey guys i have a 1981 scottsdale chevy half ton with a 400 sb in it i hooked up a tach in it about 3 weeks ago i wired evrything like it said to but when i wired it to my light switch the light wont come on with my head lights and i used a test light and turned on and off my head lights before i tapped into the head light switch but it still doesnt come on what could be the problem and the tach works perfect just not the light in it im wondering what i did wrong?
Old 01-25-2010, 04:00 AM
did you ground it? run a test wire from the battery to the tach light
Old 01-25-2010, 07:41 AM
sqzbox's Avatar
My pipes are my music
green, distributor. black, ground. red, keyed power source. white or yellow goes to the lights. Perhaps the bulb in the tach is bad? I just made a loop
on the end of the wire and tightened it on the end of the fuse marked inst lgts. The tach even dims when I dim the inst. lights out on the hwy.
Old 01-25-2010, 07:02 PM
tach light
yes wayneooo it is grounded but idk if its a good ground and how would i know if the bulb is bad in it?
Old 01-26-2010, 09:02 AM
sqzbox's Avatar
1. Connect your test light to a hot wire source and probe your black ground wire to see if you have a good ground.
2 If you do, take the same test light connected to the hot wire and probe the light wire (usually white or yellow).
If the tach light doesn't come on, it's bad or you need to recheck your wire connections.
Also, be sure your panel light dimmer is full on.
Old 01-26-2010, 04:21 PM
tach
sqz box if i dont have a good ground would the tach even work at all cuz it reads properlly when im driving around its just the light itself doesnt come on?
Old 01-26-2010, 08:01 PM
sqzbox's Avatar
OK, got ground. Put 12v to the light wire. If it doesn't come on, bulb is bad.
Hope you bought it new so you can return it for another one.
If it's used, might have to do all your racing in the daylight!
Old 01-27-2010, 08:10 PM
tach
well i did buy it brand new lol and do i connect the test light to the 12v source wire then test the connection where i spliced into my headlight switch? or do i just attach the test light to any power source and then test the connection that way?
Old 01-27-2010, 09:26 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
just a wild idea have you replaced the .................. bulb
if you speak the truth and used that test light to check the connection, it sure is not the light bulb ferry blocking out the light . you are wasting a lot of time and not using your thick head .
Glad you do not work for me .
8 post about a burnt out light bulb.....
this like the old joke: how many union guys does it take to change a light bulb ? 5, one to hold the bulb and 4 to turn the ladder ..
Tips for shop layouts and tool purchases. schnitz Garage - Tools 9 10-18-2010 11:19 PM
Ever Need more light to work.. zapf Garage - Tools 16 07-12-2006 01:59 AM
Tach Problems thecrowx Electrical 3 07-09-2006 04:05 PM
Correct way to hook up a tach in a mallory distributer tiresmoke55 Electrical 4 06-26-2006 08:29 PM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
