tach quits - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2010, 08:38 PM
tach quits
i bought a equus 8000 series tach. i have a distributor with a tach plug and a super coil from accel ( red and yellow ). the tach works shortly then quits. am i missing something from the distributor or is the super coil not compatible with a tach. i tried a inductive plug connector on number 1 wire and the same problem happened. this is the second tach ive boughten with the same problem so im wondering if its possible to get two bad tachs or if im missing something important. tach was set to v8. its for a chevy 350 with distributor
Old 10-26-2010, 08:56 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site. Post this in the electrical section and someone can help.
Cole
Old 10-27-2010, 07:41 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
look here looks like an easy install
http://www.iequus.com/Content/Suppor...-0012.revB.pdf
Sun Tach 383vette Electrical 6 12-30-2011 02:21 PM
Dash Bezel TACH, 76 Chev C20 3/4 Ton trikepapa Electrical 5 08-10-2009 12:24 AM
Tach cool rockin daddy Electrical 3 09-22-2006 04:12 PM
Tach Problems thecrowx Electrical 3 07-09-2006 04:05 PM
mustang tach wiring stang_steve Electrical 0 07-14-2004 07:28 PM
