Tach reading 500 RPM or so lower than actual - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2010, 03:24 PM
So i have a Mallory ignition box, dist, and an autometer 5" tach. When i first fire up the motor it will read a correct RPM for a few moments then drop 500 RPM. My timing light shows the correct RPM which is about 500 RPM higher than what my tach is showing. So at idle its reading 400rpm when its really 900.
I have New coil, new cap, new rotor, new ignition module why the odd job jumping around on my tach? Could it be the mallory box? Its a hyfire VII's.
Help!
Old 03-09-2010, 06:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
How new of design is the Autometer tach?
A buddy had a Autometer tach that was off.. turned out the programing in the tach was not correct. Autometer tech walked him through the re-program procedure on the phone
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
blower idle rpm problem Ratoflic Engine 7 12-01-2008 03:31 AM
vortec heads on sbc 400 camino_man Engine 16 11-11-2005 01:33 AM
351 windsor running rich ???? ve3ham Engine 19 08-08-2005 12:48 PM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 08:04 AM
