Tach reads too high - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2007, 08:29 PM
Tach reads too high
Any clues as to why a tachometer would read higher than actual rpm? the tach is from a 1984 olds cutlass 305 and is being used on a 1972 chev 350. HEI distributor being used
Old 09-06-2007, 08:48 PM
Notorious's Avatar
Hot rodder, not street rodder!
How high is it? Factory tachs notoriously read high. Probably no doubt to save on warranty claims....
Old 09-06-2007, 09:20 PM
Most factory GM setups include a tach filter between the HEI and the tachometer, and your '72 probably does not have one. Several places sell them, or you can make your own with a few inexpensive parts.
Run google on "GM Tach filter" and you will find a lot of information.
Bruce
which oil pump for a 406? high volume or high pressure? 406 ss monte Engine 23 09-10-2006 07:48 PM
283 vacuum advance nickeldimerods Engine 3 01-14-2006 05:13 PM
1969 Camaro Tach and Gauges JimKramer Electrical 2 08-17-2005 03:45 PM
1969 Camaro Tach Installation Help daveh Electrical 2 02-09-2005 11:54 AM
Emissions HELP cutsupreme Engine 33 12-27-2003 08:22 AM
