tach wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2007, 02:15 PM
tach wire
Hey guys, I converted my 4.3 to carb and am using an HEI. Which wire do I splice in to connect to the HEI for a tach reading. I've heard it's the white wire on the coil lead and the white wire on the firewall by the brake booster. Which one though
Thanks
Old 12-22-2007, 02:18 PM
79C10's Avatar
Viva la Migra!!
What brand of Tach , or is it OE?
Old 12-22-2007, 02:49 PM
It's the oe tach.
Old 12-22-2007, 02:53 PM
79C10's Avatar
Viva la Migra!!
Dang.....
I'm no help to you at this point....
sorry
Someone more knowledgeable will probably be along soon.....
Old 12-22-2007, 03:12 PM
justold's Avatar
are you asking witch wire or witch terminal on the cap ? witch wire I can't tell you , but the terminal is marked on the cap ,on second thought you are referring to a GM hei coil in cap are you not ?
Old 12-22-2007, 04:46 PM
life is a temporary assignment
There is two plug in's on a HEI one is your hot and the other one is for the tach.Hope this helps you out.
Old 12-22-2007, 06:00 PM
Sorry I wasn't very clear on my first post. I know which terminal to use on the distributor. I'm wondering which wire it is that runs from the OE tachometer to hook into the distributor. I've converted from tbi to carb. It had a remote mount coil with two plug in's. One has a red and white wire. I've read that it is the white wire on the OE coil connector and also that it is the white wire coming out of the firewall next to the brake booster. I'm wondering which one is the tach signal wire so that I can run it to the distributor.
Thanks
Old 12-22-2007, 06:08 PM
Sorry not sure about that one.
Old 12-22-2007, 06:26 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
What is the vehicle information? Year, Make,Model?
Old 12-22-2007, 06:51 PM
Again, sorry. It's a 1988 s10 auto 4wd.
Old 12-22-2007, 07:12 PM
My 2 cents worth
Wiki Edits: 3
I'll be right back with the information you need.
Old 12-22-2007, 07:42 PM
My 2 cents worth
Wiki Edits: 3
The white wire is the correct wire going the tach.
Old 12-22-2007, 09:52 PM
So it is the white wire on the OE coil connection?
Old 12-22-2007, 09:59 PM
My 2 cents worth
Wiki Edits: 3
YES! That is correct!
Old 12-22-2007, 10:36 PM
Thank you very much, ya'll have been a great help
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Starter Problems Jsquier Electrical 5 08-26-2007 05:32 PM
Wiring 4 wire tach cutsupreme Electrical 20 03-15-2007 07:39 PM
Tach Problems thecrowx Electrical 3 07-09-2006 04:05 PM
mustang tach wiring stang_steve Electrical 0 07-14-2004 07:28 PM
