Tachometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2007, 06:21 PM
Tachometer
Hi I would like to add a tach to my truck 84 Dodge D150 318 2bbl.
Anybody know how to wire in a tach on a Dodge only have experience with gm just plug it in.
thanks
Old 09-11-2007, 06:50 PM
Wiki Edits: 31
tach signal comes from - side of the coil, just follow basic tach instructions, there correct for yer truck. theyll come with the tach.
Old 09-11-2007, 07:03 PM
thats cool easy install then.
Whats a good tach to go with, nothing fancy up to 6000 rpm?
Old 09-11-2007, 07:13 PM
Wiki Edits: 31
Auto Meter, sun pro, any will be accurate enough for what u want. don't need to spend much more than $50 unless u want a 5" tach. 3/3/4" I think is decent size myself, they cost around $45 with a gauge pod.
Old 09-11-2007, 08:10 PM
Awesome man thanks for the info
probably can go to the local advance and pick on of these things up
thanks again
Correct Tachometer hookup newdad1 Engine 3 05-30-2007 09:14 PM
How do I install a tachometer? brian12c Engine 14 10-01-2005 07:39 PM
tachometer help Turbo Terror Electrical 7 02-07-2005 05:34 PM
65 impala tachometer wiring odie Electrical 2 04-27-2004 10:27 PM
Tachometer wiring fred56 Electrical 5 03-13-2003 06:27 AM
