-   -   Tachometer problem (http://www.hotrodders.com/forum/tachometer-problem-223072.html)
Michael Knight 08-19-2012 12:28 PM
Tachometer problem
I have a 1983 Pontiac Trans Am. My factory tach is starting to flicker like jump around a little but not all the time. It works but it jumps a little bit. What could be my proplem?
mmadden55 08-19-2012 12:39 PM
Most likely a poor connection at the pick up. Pull the wire at the distributor and clean the connection. If that doesn't do it, check for a break in the wire inside the insulation.
