Tachometer question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2004, 03:00 AM
Question Tachometer question
I'm currently putting a 350 chev into a vehicle which originally had a 4 cylinder engine and was wondering if anyone knew of a way to make the tacho work correctly with the new engine. The tacho runs off the coil.
Old 10-23-2004, 04:53 AM
poncho62's Avatar
Wiki Edits: 5
You will probably have to change to a V8 tach, or take yours to a shop and get it re calibrated. Factory tachs are not known for accuracy, so I would consider going aftermarket.
