Originally Posted by predator carb guru
*snip*
corection here
your right that most tachs use the ingition signal as the pickup for the tach, but tachs are designed to cut that speed in half to display crank speed
next time your out in you car do this
research and figure out the gear ratio of your car
drive down the road at a steady speed, say 40 mph
right down what gear your in and what the rpms are
multiply rpm's X gear ratio X final drive ratio X tire size ..... youll get the speed you were driving ... heres an online calculator that will do it for you :
http://www.woodyg.com/fairlane/finfo/mph.html
proof that your tach is showing crank speed, because its the crank thats conectd to the transmission
