Tach's - R. P. M. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-07-2006, 09:17 AM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
The tachometer indicates CRANK rpm. yes it gets its signal from the distributor, which is driven by the cam, which is driven by the crank.
  #17 (permalink)
Old 01-07-2006, 09:56 AM
AmericanPackMule's Avatar
Last journal entry: Adolessent J.R.
multiply rpm's X gear ratio X final drive ratio X tire size ..... youll get the speed you were driving ... heres an online calculator that will do it for you :
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXX
But to check Tach. You Drive 60 M.P.H. / Know the Cir. of your rear tires (Dia. divided by 2 = Rad. X 3.14 = Cir.) [ in Inches! ] Divide 63,360 ( inches in a Mile.) by Cir..! X "Rear end Rato." X 1:1 Trans Hi Gear. = R.P.M. of Crank. { If that number is the same as the tach. is showing; Tach is right!
  #18 (permalink)
Technically, the distributor driven tach only indicates what the distributor is doing. I can take the distributor out of my engine and rotate it with a drill and make my tach read but my crank isn't moving.
  #19 (permalink)
Old 01-07-2006, 10:12 AM
Wiki Edits: 2
your distibutor is POSITIVELY driven!!!!
  #20 (permalink)
Old 01-07-2006, 10:22 AM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
yea i know the long way to do it
i just didnt feel like typing out all the details ... lol
  #21 (permalink)
Old 01-07-2006, 12:02 PM
predator carb guru's Avatar
Mark Goulette
Well, I did some research on the subject and I stand corrected............now i feel really dumb..............................
  #22 (permalink)
Old 01-07-2006, 02:05 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
NO!!! absolutly NOt so
this is how we learn
my nick name is "slowride66" for a reason ( i guess)
I sometimes get off slower then the rest soon as I know what in doin' i figure a way to catch up
if you came off like 'A know it all' than i'd probally let you wolly in it for a little while
hell I had to look it up !
American Pack Mule is the one at fault here(just kidding)
we all learned something so ... nothing to feel dumb about
I'm Really Slow in the morning!!!
SR66
"SlowRide66"
"Illegitimis non carborundum"
  #23 (permalink)
Old 01-08-2006, 05:42 AM
R.p.m. @ Tach.
American Pack Mule is the one at fault here(just kidding)///////////////\\\\\\\\\\
WHERE DID YOU FIND IT?
MY FAULT? No problem! You arn't too slow!
  #24 (permalink)
Old 01-08-2006, 06:11 AM
I see you have a Pontiac I-Con.
I use to race a '58 @ Lions & Orange County 20 years ago; out of Precision Speed Shop. ( Stock Class: H/S ) Best e.t.=14.00 Best M.P.H. 99.99.
  #25 (permalink)
Old 01-09-2006, 06:12 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
This is the funniest post I've read yet!! Someone had to much beer this weekend...
  #26 (permalink)
Old 01-09-2006, 10:11 AM
a tach is simply a "spark" counter, the "timer interval" chip on the tach compares the total number of sparks per time interval and puts out an analog signal (0-5V, 4-10ma as ex) to control the pointer movement
you set the dip switches for 4-6-8 cylinders so the chip will divide the total sparks count so that the pointer will show the correct complete firing cycles (per minute on the dial)
Is it Jones Motorola Tachs webwiz2600 Hotrodding Basics 2 08-11-2005 09:43 PM
SunPro SuperTach II HELP! Sagacious Engine 9 08-17-2004 04:23 AM
aftermarket tachs...hook up. Rubberman2003 Electrical 1 07-22-2003 02:09 PM
Tach's and wiring problem's 70 nova Electrical 2 03-24-2003 03:07 PM
