Tach's and wiring problem's - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2003, 04:51 PM
Post Tach's and wiring problem's
I put a Auto Meter tach in my truck and going down the road and it will start going up and down for a second and be fine again. I put the tach light to my dash light where it will come on a night with my head light when. I put my light switch. I keep blowing fuse's so I put a bolt in it and you can smell the wires getting hot and it will start smoking under the dash. What is my problem can you help.
Old 03-24-2003, 01:42 PM
JUS10's Avatar
Go big or Go home
Post
run some heavier wire and an inline fuse, it'll cost ya like 5 bucks ( well canadian) and will only take ya like 10 mins
Old 03-24-2003, 03:07 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
You have a short circuit! Find out where the wire is shorted and quit using the bolt unless you need the insurance money for a car fire! Could be a bare spot on your wire or a bad light holder. Couldn't tell from your description how your light is installed.
