tail light help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2009, 08:00 AM
tail light help!
Hey guys... I'm working on making some custom tail lights...I've got the lense cut , I have the steel housing made... but now need to figure out a good way to fit the bulbs/lights to the housing..
These will be dual bulb lightbulbs for sequencing... What is a good water tight light fixture, and how to install it? Maybe rob sometime from the bone yard ..like those twist to fits? Ideas?
Thanks,
Barry
51 Ford woodie
Old 03-10-2009, 08:30 AM
Thanks,
Barry
51 Ford woodie
How about an LED conversion? You can mount the circuit board inside the housing and you only need to bring two wires out through a grommet. Alternatively if you're married to an 1157 bulb, get an aftermarket snap-in socket with a rubber seal. This should be water tight.
Help me identify this tail light! Rustydawg Hotrodders' Lounge 7 01-28-2007 10:11 AM
Where to get tail light lense red plastic willys36@aol.com Electrical 19 01-16-2004 11:39 PM
Need 4 inch Round Tail Light Buckets bg Body - Exterior 4 01-16-2004 05:18 AM
Tail light gaskets Jag Daddy Body - Exterior 0 01-14-2004 10:56 AM
34 chevy tail light toadman Body - Exterior 6 03-01-2003 05:01 AM
