tail light panel replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2007, 01:14 PM
pi71's Avatar
how hard is it to replace the rear tail panel? just the bottom part is rusted out. also rear quarter skins.
Old 05-22-2007, 02:48 PM
Knowing what you are working on might be a good start to provide an answer.
Old 05-23-2007, 11:48 AM
quarters really aren't that hard. Time saving tip is to locate and drill pilot holes in all the spot welds before you begin to r/r the part.
Old 05-23-2007, 05:44 PM
pi71's Avatar
69 camaro , quarter skins and bottom of tailpanel,,for now...
Old 05-24-2007, 07:48 AM
69's aren't all that hard, finding all the spot welds are going to be the biggest challenge. Go slow is your best bet.
Do you have the replacement panels yet? If not get them first before you even start looking at the ones on the car.
Tip #2, before you weld them in, install the trunk lid and light's and double check your panel alignments. It's easier to readjust them at that time than to break the spot welds to realign.
Tip #3, Count the number of factory spot welds you removed, and install the same number but 1/2 past the factory locations.
Most important: TAKE YOUR TIME, AND ASK QUESTIONS !!!!
Old 06-01-2007, 10:47 AM
pi71's Avatar
thanks , can it be done with a gasless wire welder?
Welding a panel in place Quarter Flash Body - Exterior 6 03-22-2007 02:56 AM
66 charger tail light Chris B Body - Exterior 2 02-12-2007 03:44 PM
64 tempest tail light change pi71 Hotrodding Basics 12 07-18-2006 07:34 PM
removing scratches from tail light lenses wheel-7 Body - Exterior 9 05-14-2005 05:20 PM
tail light buring out all the time montea Electrical 2 09-11-2004 04:49 PM
