tail light photo cell? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2009, 10:15 PM
nasmovtx's Avatar
Last journal entry: Firewall
I'm putting Caddy tail lights in my 37 Terraplane project. I useing 87-91 cadillac tail lights, and when I removed the light blubs, there was also a small, photo-cell looking device with 1 wire comming out of it. It has it's own hole, but I have no idea what it's for or how it works. Any one know more about this?? Thanks!
Old 01-16-2009, 10:44 PM
Might be a sensor for a "your tail-lights ain't working" warning light of some kind.
Old 01-16-2009, 11:56 PM
kc0kfg's Avatar
kc0kfg
Are you sure it is a wire?
Take a close look at it it sounds a lot like the fiber optic for the "cats eye"
Take a flash light and try putting it close to the end that is inside the light housing, then look at the other end of the "wire" see if you see any light.
The "cats eye" is the set of red lights you see in the rear view mirror its mounted just above the rear window on the inside.
Instead of using wires and bulbs hey used fiber optic for the indicator lights on the front and rear.
Brian kc0kfg
Old 01-22-2009, 11:45 PM
nasmovtx's Avatar
Thanks!
Thanks Brian, you are correct!! Now if I can find a Caddy I can remove the other end from, I've got some fiber optic line from American Scientific I can run, way better than light blubs!
65 impala tail light trouble low65chevy Electrical 15 07-14-2008 12:50 PM
tail light lens material - Part 2 cboy General Rodding Tech 10 03-02-2008 05:34 PM
66 charger tail light Chris B Body - Exterior 2 02-12-2007 03:44 PM
34 chevy tail light toadman Body - Exterior 6 03-01-2003 05:01 AM
Tail Light 66chevy2ss Electrical 6 08-29-2002 04:21 AM
