tail lights and dash lights quit - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2010, 06:57 PM
Okay- I am working on a 83 c-10 pick up and have now just had my dash and tail lights quit, Replaced the switch still no go, replaced all the fuses .... I can jump from the red to brown on the switch and the taillights work
The turn signals and headlights work fine.....the hazards are very dim and will barely light up the indicators
Please Help
Old 08-28-2010, 07:17 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
were either one of the fuses blown? Taillamp or instrument?
Old 08-29-2010, 12:10 AM
no they were all okay
Old 08-29-2010, 07:23 AM
75gmck25's Avatar
Check the instrument panel ground first. There is a black wire that should be grounded to a post on the parking brake mechanism up under the dash. If the wire is off or broken, it causes a lot of strange problems.
Bruce
Old 08-29-2010, 07:36 AM
LATECH's Avatar
sounds like a bad connection at the switch on the tailight connection at the switch. Either that or both switches are bad in the same place.
The instrument panel light feeder is fed from the tail light hookup .It splits at the switch then goes to the instrument panel fuse, then back to the switch .
The instrument panel bulbs ground through the dimmer part of the switch and it grounds through the switch body. Could be a printed circuit problem there.Should be easy to nail it down with a test light
Old 08-30-2010, 12:27 AM
had a similar problem on my Catalina turned out when i removed the radio and cut for a new one the case of the radio completed the ground from the upper and lower part of the dash framing caused my wipers to not work correctly either just a thought dont know if u changed the radio or even what type is in it.....
79 TA: dash lights and tail lights fuse keeps blowing Gladis Electrical 6 12-01-2007 12:43 AM
flickering dash lights tjh211 Electrical 5 05-06-2007 05:28 PM
changing dash lights to LEDs need some help mickey1031 Electrical 4 10-18-2005 08:55 PM
tail lights stay on or off?? Trav Electrical 1 11-16-2003 01:31 AM
Dash lights fade in and out firebirdfanatic Electrical 10 10-02-2003 08:27 PM
