You most likely have a bad ground on one or more of the light sockets. If they are not grounded well, they try to ground somewhere eklse, like through the other bulbs.
Ontario Rodders |
It's the black wire that comes out of the side of each socket.....
Ontario Rodders |
The ground will probably be on the body. Follow the wires from the bulb socket to see where they go. Make sure the wire is grounded well and not just partially connected to any terminals.
If (I don't know on an '85 Monte) there is only one wire the ground circuit is through the lamp assembly. Good luck and if you have more questions just ask. |
it does sound like a ground problem. you probably don't have the rust problems that we have here, but check the ground in the trunk, drivers side, close to the back end. had to repair lots of these. hope this helps.
