Tail Lights won't go out - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2005, 06:08 PM
dion's Avatar
72 Chevy Cheyenne
Hey guys,
The tail lights on my wifes 64 dart won't go out, the only way is to unhook the battery. I've gone over eveything I can think of but haven't found the problem.
Any ideas on what to check?
Thanks,
Dion
Old 02-27-2005, 06:38 PM
MadRabbit's Avatar
ya just need a bigger hammer
There is a button on the brake peddle arm that goes bad.At least that the way I fixed that problem on my ride...if its not that I'm lost,good luck
Old 02-28-2005, 11:33 AM
dion's Avatar
72 Chevy Cheyenne
I'll give it a look, thanks.
Old 02-28-2005, 03:41 PM
have you tried to pull up on the pedal? sometimes the brake pedal on my chevelle needs alittle nudge up to get the brake lights to go off. i think the return spring is alittle weak after more than 30 years of service.
Old 02-28-2005, 04:31 PM
milner's Avatar
first thing you have to check is to see if it is tail or brake lights. if it's brake lights then check the brake light switch like everyone said. but if it's tail lights,check the headlight switch for melted block or wiring. good luck!
tail lights screwed. need help 406 ss monte Electrical 6 12-26-2004 08:04 PM
Need some opinions on tail lights Bluepen Body - Exterior 5 06-29-2004 08:57 AM
Wiring Tail Lights & Turn Signals horvath Electrical 15 04-30-2003 05:04 AM
Tail Lights Jpgregoire Electrical 3 11-13-2002 07:45 PM
EZ wiring harness, tail lights 53chev Electrical 4 11-05-2002 06:23 PM
