Which tail pipes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2012, 09:14 PM
Madmax305's Avatar
Which tail pipes?
Hey guys, I have a 1967 Elky with a sbc 350. It is making around 350 HP. I have Heddman Elite full length headers with 1 5/8" primaries and 2 1/2" exhaust pipe which dumps at the mufflers. I am looking to add tailpipes, which would be better? The flowmaster 2 1/2" or 3" tail pipe which will exit behind the rear tires....
Old 07-15-2012, 09:30 PM
How fast is fast enough?
just go to a muffler shop and have them fan you up some 3" pipes.
Old 07-15-2012, 10:39 PM
327NUT's Avatar
As said above.....any muffler shop can install the system or look of your choice.....I would however stick to the 2 1/2" size.
Old 07-15-2012, 10:40 PM
Greg T's Avatar
www.krusinklassics.net
I've got 2.5" running to the muffs and 3" out the back. I love the extra depth of the 3" and they take away the high frequency rasp.
Old 07-16-2012, 04:23 PM
Madmax305's Avatar
Why not go with the 3" pipe. Is this size more appropriate for big block or high horsepower applications? Could I possibly lose torque by going with the 3 inch pipe?
Old 07-16-2012, 08:08 PM
vinniekq2's Avatar
I run a full 3 inch mandrel bent system with X pipe and it sounds and works great.I had a 3 inch none mandrel bent exhaust without a cross over before but it was noisy and sounded great!
Old 07-17-2012, 10:06 AM
1971BB427's Avatar
Not much gained by going 3" after the muffler if the first part and the muffler are all 2.5". I doubt the lack of back pressure will hurt, but if you want a 3" tailpipe just have the shop run 2.5" back and tack on a 3" end for the last 12" or so.
350, exhaust
x-pipes really help? chevyv8_power Engine 8 04-02-2008 12:09 AM
adding tail pipes stinky jinx Engine 1 06-22-2005 10:15 PM
tail pipes or no tail pipes? 92camaroZ28 Engine 13 01-12-2005 11:58 PM
H pipes and X Pipes Native Gearhead Hotrodding Basics 12 12-17-2003 03:05 PM
Pipes on a V6 grandprix601 Engine 3 10-30-2003 03:50 AM
