Tail Shaft Housing...Long or Short??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2007, 01:02 PM
Last journal entry: more...
I know most TH350 tail shaft housings are either 6 or 9 inches. I tried measuring the one I bought a week or two ago and it was in the sorta in the middle. Where do I need to measure from to find the true legth of the housing? Thanks_LT1_Performance
Old 07-11-2007, 01:20 PM
tail- housing
Where it bolts to the case, to the end of the housing, is where I measure.
Old 07-11-2007, 01:24 PM
I thought so but, thats odd...
Well initially thats what I assumed but when I pulled out the tape measure it was around 7 to 7.5 which I thought was kinda odd. I know the TH350 had other tailshafts, does anyone know their measurments? Thanks_LT1_Performance
Old 07-11-2007, 02:08 PM
tailhousing
The 700R4 housing is about 7 and 1 quarter inchs long.
Does YOUR TH350 have a modulator? The 700R4 will not.
Old 07-11-2007, 10:14 PM
http://tciauto.com/Products/TechInfo/trans_dims.asp
Disassembly of tail shaft question DaSouthWon Transmission - Rearend 6 05-23-2006 09:12 PM
Crosley? Going rate for TH-400 short output housing? DrChop Transmission - Rearend 4 03-10-2003 09:29 PM
T-350 Long vs short shaft change zachscc Transmission - Rearend 2 01-21-2003 01:53 PM
