tail shaft swap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2005, 09:43 AM
camaro409's Avatar
YOu KnOw IT
tail shaft swap?
there was a drawn out question here but i have found my answer
Old 05-15-2005, 11:39 AM
Crosley's Avatar
Wiki Edits: 1659
you are welcome.
Tail shaft change??? arborlis Transmission - Rearend 6 08-31-2003 08:32 PM
Tranny swap, What size tail shaft? Ralph Horak Transmission - Rearend 2 01-12-2003 05:35 PM
Can you swap tail shafts on TH350s? briwill Transmission - Rearend 5 12-11-2002 08:36 PM
Ford Top loader tail shaft 65 stang Transmission - Rearend 1 11-28-2002 12:10 AM
