Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tail, Signal and Brake loght wiring
Old 08-19-2012, 07:05 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
See attached schematic for turn, brake, taillight wiring.
The brake light circuit goes to the turn signal switch. This is what your harness has.
If you can add another wire directly from the brake light switch to the LED assembly, the brake lights will work even when the turn signals are on.
vicrod
