Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tail, Signal and Brake loght wiring
Old 08-20-2012, 12:11 PM
ogre's Avatar
ogre ogre is offline
the 'Duracell Project'
2 choices:
tie the stop and turn together will give you brighter stop lights
or if you have a separate 3rd brake light circuit in your harness use that for the brake circuit. youd still have the brake light function through your turn signals too.
i'd try the second idea to see if it works right and give sufficient turn signal lights
